I have a 76 max 11, and was wondering about the 2 tubes coming out of the gas tank. I assume one is for the fuel line but if the second one is a vent, then why do they both go to the bottom of the tank?
Gas Tank
Originally posted by mike d View PostHI. If it was originally a 2 stroke it could be a return line for excess fuel. More knowledgable people will chime in and confirm or deny. Good luck with your max. Later mikesigpic
return fuel line
Mine is around the same year and the metal tank also has two lines. I use a pulse pump and honda clone engine. I'm using the second line as a return line as well. Without the return it would sometimes drip gas from the carb so added the return line.
