New to 6 wheeling I have a Maxx IV with a split shift mod - the left shifter is stuck in forward how do I fix this????
split shift t-20 left side stuck
If the machine has been sitting up a while, the diamond shifter could be stuck where it enters the transmission. Disconnect the linkage at the diamond shifter and see if your linkage moves freely. If it does, squirt some penetrating oil under the diamond and let it soak down and hopefully it will free up. Trash tends to collect under the diamond and it can create a problem. Good luck.
First being new, do you know you have to rock in the seat to get most Max's into and possibly out off gear, sometimes with a slight burp of the throttle?
If so... I know it's hard and may require a friend to operate the shift lever as it's such a distance, but watch the linkage move to see how far back the bind is if the linkage begins to bow it could be the diamond shifter in the trans cocking causing the bind and perhaps re adjusting the metal strap keeper over it will help.
Sucks it's a IV as you may have to remove the table to see anything going on under there.
Good lucksigpic
