Hi guys,
After an extended hiatus, I am finally "back in the seat". I had a starter and power problem, and after several inquiries here, and hours trying to do the job myself, I finally gave up, and looked for help. My local "B&S" service shop turned out to be a great help. I only wish that I had contacted him a year ago....it would have saved me hours of aggravation, bloody knuckles, and much less swearing. Turns out he used to work on the "former" local MAX dealers machines. He said it had been a while, but he knew my problems, and once he got it on the job rotation, it was done in just about 2 hours. I only needed the starter drive replaced, but the darn thing is nearly impossible to reach for a older, heavy set guy with big hands. Even he said that he was standing on his head for an hour. Long story short, the starter is back in business. The power issue was solved by shrink tube on the plug wire...he figured it got hot/burned at some point and was shorting out...he put some shrink tube on the wire and that seemed to fix the problem. He then gave it a quick once over, and cleaned some crud from the carb bowl that I had either missed or showed up later. I have since had it back for a few days and managed to fix a couple wiring issues. The grand-kids had broken a wire off the heated throttle cable switch. Another wire for that had broke on the plug back by the engine. I have repaired both of those issues. I had another wire for the winch that kept coming off. I put on a new connector and that is now fixed.While I was at it, I replaced the 6 year old battery. Now the MAX II is running and I am back having fun again. The grand kids are happy as well.
