2008 Max 2 questions from a nube
  • 2008 Max 2 questions from a nube
    Gents, I just bought a little used, low hours Max 2 and I have some questions concerning modifications for it. It has the 16 hp Briggs engine.
    1. How would chains work instead of tracks? Seems to be an easy install for the front and rear tires, proper fit and clearance would seem to be easy. Has anyone done this and if so, how well did it work?
    2. Access to the engine compartment:
    I’ve read about the ‘top cut out/refit method here. What about cutting across the whole top piece from right behind where the rollbar is, completely across the back allowing completely lifting off that part only undoing 7 wing nuts and disconnecting the tail lights?
    Would much appreciate any and all advice and comments, thanking you all in advance for them.
    If you sell the tracks for the 2 let me know
      Didn’t mean to mislead. I don’t have tracks. Just trying to find if others here may have used chains and about the rear body mod I mentioned.
        I’ve got a friend who ran chains on the back of his MaxII and said it helped considerably. More room on the back tire for chains. Still won’t be as good as tracks but should help.
          I have to wonder what "additional traction" on one axle/tire will do to bearings, chains & turning ability???
            Hi EZDuzit
            I would install the red spring on the driven clutch, it will keep you in low range longer but top end and acceleration will not be effected, you will see a big differance.
            Also do a split shift, look on here or the other 6x6 site for info.
              Gents, thanks, I’m going to install the chains on the front and give it a go. I figured engine weight in the back would help enough there. This Max is most always used in the southern swamps so a little extra traction I’m thinking will help.
              Does anyone have any comments or advice on my asking about the rear portion of the top section being halved for easy and full access to the engine and rear drive parts? Anyone?
              Much appreciate you guys and sharing your collective experience. Saves a lot of misfires and wasted effort for a nube, I’ll tell ya.
                i think you can modify any way you like for easy access as long as it does'nt effect the strength or lets water in . i cut my front floorboard in 2 pieces and it is much easier to remove but still works fine. seems if you cut all the way across the tub part right behind the seat back .. then you could remove that whole back section to do your work by undoing the wing nuts . then put it back when done . i would sure think that the lower tub is plenty strong even if there is a cross cut in the tub top. there are guys who don't even have the tub top on their machines . i may do the rear on mine and i will let you know. the only thing i see about that is you got wires to the tailites you would need to modify and if you want to raise the front of the tub you would need a way to hold it up when lifted. just a few thoughts... i will look at mine this weekend and see if it's feasable. johnboy va.
                  John boy, many thanks. It’s parked in the woods right now having spent all day in it putting up deer stands. Upon returning from an immediate road trip I’m gonna get on it pretty quick and will come back with what I do to the back of the top works. Much appreciate your passing on about the floor pan. Briefly thought I should do something with it cause when taking it out this evening I managed to dump most of the twigs and leaves down in the bottom. I know I’m preaching to the choir on that!
                    Are you talking about just chains on SINGLE wheels, or wrapping a long set (possible 2 semi truck chains linked together) all the way around all 3 tires on each side? I would think the chains on all 3 tires, both sides, would work great. And be less strain on the drive train due to more play in the chains? Or at least link the 2 fronts, or 2 backs, on each side. Now I think I may be looking for some tire chains.....
                      i also think a whole set over all 3 wheels is the way to go . better traction all around and you keep the tire diameters the same. you can add more of the chains going over the tires for even more traction. if you can't find chains already made to fit your tire size , you can buy the chain in bulk and make your own. once you cut the 2 long side chains to fit , cut the short cross chains and connect them with quick links to the long ones maybe every 6 to 8 inches along the length. the final hookup can also be done with 2 quicklinks . let the air out of the front and rear tires .. pull the chains tight with ratchet straps .. connect .. air up the tires . good luck and post a picture if you make them . j.b.
                        also look at the '' terra grip tire chains '' . you can use 1/4'' x 2'' pvc belting ( mcmaster carr co. ) to go across the tires . connect them to the side chains with some '' u '' shaped straps and a bolt . they would make some pretty good tracks . johnboy va.
                          Installing chains on the front two tires only. The types I’m speaking of would be like those sold by Cabelas advertised for 4wheelers. I do know that these are the cat’s azz and work very well on 4 whlrs , like awesome. Having said that, it’s more than wise to have a winch on same.
                          I’m just wanting a little extra edge and figure the front end is lighter than mid point and rear, thus less stress on the total drive train. Also the front bearings, etc. are easier to change out than, say, the rear ones. That’s my line of thought on it. Before all or any mods comes the winch. For that, Harbor Freight, 3500 lb. one with backing plate causes been there and done that one time too many.
                            Johnboy, I much appreciate your input and ideas on this. I had not considered total chains on both sides. Ain’t rocket science when I think about what you’ve said but it never crossed my mind!!
                              ez..the cabelas atv tire chains look good . i was thinking you were going to use chains in one long piece like tracks , but i guess your thinking chains around each tire . either way sounds good. i have seen them wrapped around all 3 tires like tracks and then inbetween the cross chains some rubber belting added across to give more '' footprint '' on the ground. i did some that way when i made a homebuilt set. if you go around each tire you will have plenty of chain if you decide to connect them as one long track. j.b.
