Since it turned colder and snowed my first outting was plowing my driveway. It moves forward and backwards just fine and turns fine but there is always a “grinding type noise”. I can only describe it as it seems the trans isn’t fully engaged but it does it at all speeds and both directions? Almost sounds as if you had the rubber lugs on a snowmobile track rubbing on the tunnel for a better analogy. Maybe it’s just “chatter” I’ve heard about for the T20? It’s only done it since it turned cold. Seemed fine the couple rides I took this summer when I bought it (94 max IV). Any help or input is appreciated as always!
Thought maybe a chain was rubbing the floor pan but that doesn’t seem to be it. Chains and sprockets all look good.
Thanks,
Newbie owner
Thanks,
Newbie owner
