I have had endless good times with broken axles on my max lv last winter running RI factory rubber tracks. I come to the conclusion that the benefits of having tracks is great until you have to figure out how to get it home with power to only one side.for those of you that had been there it does not matter how big you and your friends are, your not pushing that darn thing that would be almost as easy as working on it. Any way I have only recently learned about the unavailable axle support brackets, I always thought they were extra support for a snow plow. After trolling the forum it seems some of the community swears by them . I called RC at RR he does not have any and informed me that RI is out of business so I will have to make them. I am guessing it would defeat the purpose if they were not close to exact to the inside alinement of the axles probally help with premature bearing wear. so the part I'm not sure of is do they go against the tub? Or on the outside of the bearing cages? I assume outside of the bearing cages closest to the wheels??? Any and all feedback is appreciated. Thanks sherman
Max lv axle support brackets
Ya i have dual Adair synthetics on mine tied together with the steel rail in between them check out my Facebook page for more info let me know if you need the drawings
https://www.facebook.com/photo.php?f...9673280&type=3Last edited by countrycummins99; 01-23-2019, 01:56 PM.1996 MAX IV ,KUBOTA DIESEL
MAX II 30HP Bandolero
just a thought ...for some feedback. how well would it work if before a axle was installed in the tub , a extra outer flange and bearing were slid on the axle and then long bolts ( 3 ) the right length would be installed from in the tub thru the first bearing flange then a nut and locks to tighten to the tub , then another nut and washer spaced out further , slip the outer flange and bearing on and tighten with nuts and locks. it would need to be all thread bolts and the outer bearing could be as close to the hub as possible for extra support. basically a outer bearing supported by the three tub flange bolts. j.b.
