how often do you need to adjust the plungers on the max 11 while plowing today felt like in wasen't engageing on the left side its a 1999 mostly the same parts as when it was new checked the plungers about 20 hour ago only gets maybe 5 to 7 hours a month drive time in summer and maybe 4 hours of plow time a week in the winter the primary clutch and starter and drive belt are the only things ever changed since 2000 have had no trouble with it think I just don't get out as mutch as I would like to
shifting and braking
thanks I'm usealy that way also and I think thats why most of my stuff last as long as it does always beleaved in prevented maintaince for years my father always asked if you don't have time to do it wright when will you have time to fix it. Just belive its a learning curve with these machines
There is a picture of the tool at
T-20 Band Adjustment Tool - Amphibious ATV Pictures
The thickness is shown as .190 to .200 inch
Width of tool is 9/16 (.5625) inch
Width of the fork tines is 3/32 (.09375) inch
That leaves 3/8 (.375) inch open for the slot.
The slot is 7/16 (.4375) inch deep with a 3/16 (.1875) inch radius above slot.
That makes it 5/8 (.625) inch from bottom to top of radius
The flat section of the tool with slot is 1 1/2 (1.5) inch long
The picture in the link show the radius above the slot as 3/8 radius but should be 3/16 radius to fit the slot width.
