Chains?
  • Chains?
    How tight should the chains be? How do you check this? They feel fairly tight to the touch.
    if you grab the chain between the sprockets, you should have a total of 1 inch deflection, 1/2 up, 1/2 down from center. check it with the tires off the ground, as it may have the part of the chain you can grab in a bind with it on the ground
      Thanks Racerone!
        Doesn't 1 inch seem kinda loose? I've alwasy heard of 1/4 to 1/2 inch total. Just wondrin'.
        It's all just nuts and bolts.
          Make sure that you keep turning the wheels while you are checking chain tension. You may find a spot where the chain is too tight.
            Yes, it's 1/2" total.
              sorry, my bad. i was thinking 1 thing and typing another
                is that a loose half inch like you can jiggle with a pinky, or a tight half inch like starting to draw a bow? I guess how much play you see depends on how hard you push/pull...
