How often are you guys changing the oil in the T20 ?
T 20 oil change
Trans fluid is recommended to be changed out every 60 hours of drive time. It says this on my T20.
FYI, in case someone doesn't know, it uses 32 ounces of ATF Type FA fluid.
Note that others use synthetic fluid instead.
Some use 28 ounces mixed with 4 ounces of differential modifyer.
I use 28 ounces of NAPA ATF Type FA mixed with 4 ounces of Equa-Torque additive in mine, with very good results.Stand for the Flag. Kneel for the Cross.
