Uggh...question?
  • Uggh...question?
    Greetings! I'm new to the 6x6 world. I just aquired a Max IV, but the owner put a foot throttle in it which I have tossed. I purchased a new throttle cable and orginal hand throttle for it. However, since the other was"rigged" up, I'm not sure where to run this very long throttle cable. Does it drop down the handle and go to the right side of the body when sitting in the driver seat outside the seat frame, up the middle, or left side? Again, given it's a 1997 based on the serial number, I don't see any clips to fasten the cable down. Do you zip tie the cable to the frame? Dip stick questions for sure, but I gotta ask. Be prepared as there will probably be more over time! Thanks again to all!
    Carl a.k.a. 350xrider
    Zipties sure if it works. you will soon see one of the best parts of this hobby is the customization people do to these machines.
    350xrider? would that happen to be the honda atc 350x? I just bought an 85' and in the process of going through it.
      You can see the red wire for the heated throttle cable in this picture.
        Thank you!
