Max II TIRES
  • Max II TIRES
    Hello all. Don't know if previously discussed but are you able to run 22" tires on a Max II?
    Thanks!
    Mike
    Yes. You can actually run 24" Argo tires mounted on Argo wheels on a Max2 without body modifications. I've mounted 25" tires on 2 Max2s as well, but you will have to modify the tub for that.
      I have 25" on my Max II, but that is with 1"extenders, and I mounted a 6"x 4" tin plate over the front tire to protect against rubbing the tub.
