Help please!! I have a 2006 max ii and it will not start via key. When I turn the key it doesn't even make a sound. I took the battery to get it tested and it works fine. However I can start it with the pull starter. Also winch won't work and all lights and amp meter dont work. All electrical doesn't work. Once on it will only stay idling with the choke out. If i push the choke in then the engine dies. Any advice would be helpful. 18hp b&s vanguard
No electrical power
Check your fuses, make sure wires at engine are plugged in.
Clean carburetor.sigpic
UPDATE: my electrical problem was a blown #2 fuse and a missing fuse that was added to the harness. Once those were replaced everything worked again.
I think my choke problem is bad choke cable routing because my choke lever is backwards. When I pull the choke out, the little Carb "butterfly" is open, when I push the knob in the "butterfly" is closed. Isn't the choke ON when the carb butterfly is closed?
