If I buy a brand new 23hp vanguard engine will I be able to use it in the max? Is this a direct bolt on.https://www.ebay.com/i/131594074442?...IaArk-EALw_wcB
2019 vanguard 23hp engine
Originally posted by DrywallDoc View PostIf I buy a brand new 23hp vanguard engine will I be able to use it in the max? Is this a direct bolt on.https://www.ebay.com/i/131594074442?...IaArk-EALw_wcB
Something like that would probably be closer to what you need. I bought a 16hp for my argo off amazon. Only thing is I have to set the idle governor down some. In other words engine idles to high and engages the belt. Briggs makes a tool to tweak the tabs for the springs. Use a tach and set it. I would think you would have to do the same. May be wrong though,.
This is the exact engine I was looking at. https://www.ebay.com/c/28018456692
I wanted to make sure it was the same as the 18hp other then displacement. Is the shaft height/length the same? Is this a direct bolt on and go?
Also what does it mean when it has the shaft size as 1"x3" or 1"x 2 29/32" or 1"x 3-5/32"? Which one do I need??Last edited by DrywallDoc; 11-17-2019, 01:04 AM.
Regarding the shaft size, the 1"x3" or 1"x 2 29/32" or 1"x 3-5/32" refer to the diameter and length of shaft. I think the 1 x 2-29/32 is pretty common. As far as everything bolting up the same, I suggest this: Find the owners manual for your existing engine and the replacement you desire. In the back of the manual there usually is a dimensioned drawing of the engine. Compare the two. One thing you will have to modify is the wiring.
I've had several B&S 23 hp motors, they have all been duds. Overheating, backfiring, excessive oil and fuel consumption have plagued the three I have owned. I think going to a B&S 18-21hp, Kohler or Honda motor, is a better idea.
I've got several machines with those engine and have never had problems. Several others have also mentioned the same issues with the 23hp Briggs engines.
I worked on a guys machine with a 23 installed who complained of heat, I threw a 5" fan blowing air onto a combo of oil cooler and and blower fan that seems to have helped some. 23s build a lot more heat than 16s.sigpic
