My max ii has the old style lower tub, I was wanting to eventually run 24 or 25 inch tires but it's looking pretty tight around the front tires(22x11-8). I'm sure there's some droop going on. How much space should there be around the tire and those bulges on either side on the the old style lower? Is it forgiving enough to heat it and push it back some for the clearance to fit 24s or 25s? Or is the old style tub pretty much going to limit me to 22s without doing extensive reshaping/rebuilding?
Old style lower tub
I'd say from the experience I have that your probably limited to 22s at the biggest with that style lower.Originally posted by Dw89xj View PostMy max ii has the old style lower tub, I was wanting to eventually run 24 or 25 inch tires but it's looking pretty tight around the front tires(22x11-8). I'm sure there's some droop going on. How much space should there be around the tire and those bulges on either side on the the old style lower? Is it forgiving enough to heat it and push it back some for the clearance to fit 24s or 25s? Or is the old style tub pretty much going to limit me to 22s without doing extensive reshaping/rebuilding?
That's good to know, thank you. I kept reading 24" Argo tires will fit but after mounting my new tires I thought to myself it's awful close up front to fit another inch or two of tire without rubbing. It kind of makes me feel a little better about these skinny deestone tires, if they were as wide as they should be I think they would cause issues up front.Originally posted by dave phelps View PostI'd say from the experience I have that your probably limited to 22s at the biggest with that style lower.DanW
