I have a max 2 and the secondary clutch started making noise about half way open. Should there be any play when you lift on the clutch? It is a small amount but does move.
Clutch noise
I should have asked, what type of noise is present? Is there a power loss? Is your belt slipping?
It could be a worn belt, worn spring, sheared key, snap ring yadayadayada.
There is generally some in out play in a t20, you may feel this going up and down.
There is a clutch guide on the home page.sigpic
Not sure if this will address your specific situation but you mentioned alignment. Check out page 6.
Sounds as if a new belt may be a good start, the clutches are slightly off center by design. As jbf stated the bushing wear may be an issue though I don not think comet clutches are as sensitive as the Argo clutches are to bushing wear. If you can spin the movable face free of the hub? ( drew a blank there) and it rocks noticeably bushing is suspect.
Your belt should sit about 1\8 or so above the driven when new, check the belt for glazing, check the spring for any seriously reformed coils especially multiples.
Posting a picture of your clutches and belt could draw some possible answers.sigpic
