It will fry the wiring of the smaller rectifier when the larger alternator is at full load. could install a circuit breaker but breaker will eventually fail.
Max IV external alternator install
Didn't think about that. I was already planning to disabling the internal alternator by disconnecting the regulator as soon as I get back to messing with it. I am also planning to purchase a larger pulley (maybe 6" vs 4.5") to make the external alternator excite at initial startup without revving the engine.Borrowing tools is for the weak.
2000 Max IV, 25hp Kohler Command, 26" Titan Tru Power AT's
1996 Max IV, 18hp Briggs, 24" Serwas
1998 Max IV (project in waiting)
1995/1999 Max II, 16hp Briggs, 21" Rawhides
Hustler 950 (Project in waiting)
I disabled the internal alternator by disconnecting the voltage regulator. I also did more testing and found that the external alternator does indeed charge at initial startup without revving the engine to excite. I don't have an explanation for why it did not before, but it does now. I will leave the 4.5" drive pulley in place. The alternator puts out 14.7v at idle.Borrowing tools is for the weak.
