Ok, so here goes. I recently picked up a 93 Max II with the original 16 hp Vangard motor (date stamp is '93). I've replaced the plugs, coils, new gas, cleaned the carb, compression tested of 150 on the rear cylinder and 140 on the front, but still we're not smiling. The Max idles pretty good but as soon as I start to give it the gas, it blows gas out of the carb and back fires and has no power. I believe it is a fuel problem and I see I have two choices, rebuild it the carb for $75 or get an Ebay carb complete for $50. Do y'all think I've trouble shot correctly in that my problem is the carb and should I go cheap on Ebay or rebuild? Thanks in advance. Fred, sitting broken hearted in my Max in the garage...
Ebay carb or rebuild the carb...
I'm leaning toward a carb problem. It could be flooding itself thus causing the backfiring and poor running condition. When you do run it, and if it is flooding itself, the plugs should be black. Your post says you cleaned the carb. Did you actually disassemble it, remove the jets, soak it in a cleaner, run a wire through ports, etc?
Also, did you properly gap the plugs and coils?
I properly gapped the plugs and coils. I pulled the carb apart, spayed most of a can of carb cleaner on and through the jets and bowl. I used a small wire and I ran it through the jets. On the plugs, the front one is white or looks normal and the back one is black and wet. It looks like gas fouling
pull the back plug and make sure its firing - through the plug, not just through the wire. You could have gotten a bad plug or coil. If the carb was dumping fuel into the engine it should show up on both plugs.
Does the coil mount in only one position (I think so but its worth asking)? If not, is it mounted wrong and thus the ignition timing is off on that cylinder?
Ok so here is the latest. I pulled the back plug and checked it is sparking. I checked the coils, they are not installed backwards and are gapped correctly, yes I really did check, we're all human. I checked the valve clearance and adjusted all 4 valves. I put it all back together amd it fired right up. It idles better and ran at about 80% which is a lot better than 10% power like it was. After about 5 minutes it started missing and was getting worse. It is blowing oil out of the PCV so much so, it was dripping out of the air cleaner and made the Max smoke like crazy. This thing is making me learn, so thanks for the advice and keep it coming.
my guess is that you are losing spark on the rear cylinder. you could try removing the small black wire that connects the 2 coils. if it runs fine without that wire you need to replace that. that wire has a diode in it that can cause problems. note that the engine will not shut off with the key when that wire is removed unless you have a functioning antibackfire solenoid. you will need to use the choke to kill it.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
I saw about removing the black wire on another post and did that yesterday as well. The plugs look ok. There are two things I need to adress in addition to the black wire. First the breather problem of oil blowing out of the pcv valve. I'll get a new pcv after I pull the motor and get all of the 30 years of oil and grease off of it to see if any gaskets are leaking. The next thing and kinda important is taking care of the sparks that were coming off of the heat shield at the front top of the motor and at the bottom front of the fly wheel while it was running. Good thing was even with the sparks there it was running good. LOL! It wasn't very safe though. Once I get it cleaned up and put back in I'll send an update.
I believe the spark was from the ignition system somehow. It was sparking like the plugs do. The motor is also blowing g so much oil out of the PCV valve the oil is being g sucked into the engine. How do I know, when I took the intake manifold off there was oil just laying there. If I do replace the PCV valve will it stop blowing oil? With the amount of oil covering everything it could be shorting the connections somewhere... Is that the ignition module on the front heat shield or is it part of the charging system (I know I'm a newbie to the small engine world)?
ignition is under the flywheel, the module on the cooling shroud is the rectifier for the 12v system. blowby into he air cleaner could be from over filling the oil. or by a bad pcv. a oil wet air cleaner will make the motor rich. The governor adjustment also can cause the carb o spit back fuel due to it opening the throttle very fast. Governor adjustments are a PITA. best to do a goov bypass.Acta non verba
