Biggest tire I can put on my 1977 max iv
  • Biggest tire I can put on my 1977 max iv
    Hello everyone this is my first posting. I have a 1977 max iv with a chaparral 454cc two stroke. We replaced a lot of parts and the machine runs like a beast. The problem I have is it has 21x11x8 tires and it rides like a tank and no ground clearance. I would like to buy new rims and tires in 26x12x12 there seems to be enough clearance under the tub to fit them but I’m not sure. Can anyone help me on this.
    A Max IV will work fine with 26" tires, that is the size of the terra tires that originally came on them. The Max II is limited to sub 25". I wasn't aware the Max IV was in production as early as 77.
    Tire manufactures can over or under exaggerate their tire sizes so be cautious of that. One companies 29" tire could easily be 27" and another could be 30"
    http://www.6x6world.com/gallery/02-m...o-buffalo.html these are ht biggest I've seen on a Max IV
    The best Max IV tires are the stock Terra tire 26" tall very good in all conditions great swimmer.
    And the Vendetta tires, these in their max width are as close as you can get to having tracks. Also equally good swimmers.
      Thank You for responding. A while back I bought some parts off of Richard and he looked up my serial number and thought it was a 76 or 77 model. May even be a rim model? Would you happen to know where the best place to purchase the rims for this machine and do I need a special offset or something of that nature. She’s not a perfect machine but man is it fun. I won’t really. E swimming with it, mostly in some mud with a little water.
        You can run lawn tractor wheels, I think some of the old cubs had 12x10 or 12x12 wheels, or check out jeds tire wholesales, they seem to have a good selection, but you might get orange wheels just be sure to get 5x4 1/2" lug pattern. Same as 90s jeep and small ford 5 lug.
        DanW
          With that engine and the year, it sounds like it would be a RIM (before Max/RI started making them). It usually says RIM up front, but maybe it had a body swap.
            I use lawn tractor tires. These are WAY better than the terras. Excellent swimming, fantastic mud, awesome snow. I put a little more air in them to lessen the steering effort.
              Originally posted by mfenmor View Post
              [ATTACH=CONFIG]18293[/ATTACH]
              The Dico tire was factory for a while, the Trupower may have made it on some.
                I wish i had another set for my other Max IV, but I forked out around $1200.00 for these.
