Guy goes into a garage to grease bearings.....
  • xbunsenx
    replied
    Those tires look like they have good swim potential.
  • mfenmor
    replied
    Originally posted by john swenson View Post
    those are 28 '' tires ? what size rims are needed ? j.b.
    I'll use my 12x12 rims, but they say a 12x10 rim will work.
    Now to make some beadlocks.
  • john swenson
    replied
  • mfenmor
    replied
    Look what just showed up at the door today.
    Now I HAVE to finish the portals. 28s won't fit on stock Max IV.
    OK, so now I'm WAY past the $700 in the hole.
    I'll get back to the portals when I finish the repairs from Busco Beach adventures.
  • xbunsenx
    replied
    It's looking really awesome. I look forward to seeing how it all goes together.
  • mfenmor
    replied
    Almost done with the secondary shafts.
    I need to get another keyway cutter. These shafts are harder.
    Next, poke some MORE holes in the boxes.
  • mfenmor
    replied
    I finished machining the primary axles today.
    My home made splined axles. Just 4 keyways cut in shaft.
    I opted out of the six splines as the hubs would have been too difficult and expensive for me to do. 4 is enough.
    Tomorrow I'll start on the secondary axles.
  • mfenmor
    replied
    96 1/2"-20 bolts cut to length.
    [ATTACH=CONFIG]18369[/ATTACH
    I finished broaching all the hubs and welded the sprockets to them, still waiting on 4 more sprockets. I'll send them out to have the teeth induction hardened.
    Notice the new parking brake disks. They will be hydraulic actuated.
    Next, cut keyways in 12 axle shafts.
    Mount bearings
  • mfenmor
    replied
    162 holes poked, 144 more to go.
    I think I need a new drill press after this. It really didn't like all the 2" holes I did.
    Tomorrow, $278.00 worth of fasteners arrive. That's a lot of bolts. I must be nuts.
  • ARGOJIM
    replied
    stupid autocorrect, edit option in photo.
  • mfenmor
    replied
    Taking pics with phone sideways?
    Open the exit box and rotate them.
    No, holding phone upright.
    Exit box?
  • ARGOJIM
    replied
  • mfenmor
    replied
    Can anyone tell me why my pictures are all sideways? when I load them to my PC they are right side up. Soon as I load them here, everything goes sideways.
  • mfenmor
    replied
    She's got legs
    She's got legs, but no feet yet.
    8 1/2 degree cant puts all the axles 30 inches apart. Good for a 28 inch tire. it's not possible to spread them further apart without having unequal length boxes. I'm too tired to do all that math.
    Hopefully this weekend I'll get all the axles installed (12). My sprockets are back ordered. for a couple weeks.
  • mfenmor
    replied
    Originally posted by xbunsenx View Post
    I can't wait to see the completed design for those portals.
    I am speculating that you are not going to use chain inside the portals, instead you are going to have two or three gears hence no adjusters needed. If so, are you going to seal the boxes up and make it like a transfer case with oil (fill plug, drain plug)?
    You will have to wait and see. They will be oil filled.
