Body band questions?????
  • Body band questions?????
    I just purchased a Max II. It is a 2006 model. I want to add a winch and some other things. I have looked at this site for a couple of days and have seen many pictures of body bands of Max IV and some other 6 wheelers, even a few Max II's.
    My question is, on the Max II pictures I have looked at it seems that there is no band on the inside of the tub. It looks to me that you need a flat piece of steel running around the inside of the lower tub, maybe 3" wide, then a 2x2 angle iron on the outside sandwiching the body between them. Probably put bolts ever 18" or so. It seems that 1/8" thickness would be plenty, but I could be mistaken.
    Is my thinking right, or am I way off base with this.
    Also, I am looking for axle braces. I would like to add a snow blade and from what I have read so far axle braces are necessary. If they are, where in the world, short of going to a machine shop and paying my friend to fabricate them, would I find axle braces for a Max II?
    Thanks.
    Most just do the visible band on the outside and large fender washers on the bottom side . This cage was involved in a nasty high speed rollover(s) and only pulled 2 bolts loose
      Thanks racerone3. I will think about that. I was also considering putting the angle iron all the way around on the outside, and just an inside piece of steel across the front and back and two short pieces at intermittent places on both sides. That would be easier than a band all the way around the inside, not as strong, but a lot easier.
        Hydromike and I both did a band sandwiched between the body halves on our Attex tank trainers, but it was only done to add body support.
        tons of work, and on a POLY bodied machine I don't think you would ever need to go that far
          racerone3 I looked at the pictures in your link and have a question. It appears as though you mounted the angle iron body band on the top part of the max ii body shell, where the two pieces come together. Is that correct, and if so did you just use washers on the other side or is there some steel reinforcement? If this is mounted this way, you have to remove the body band to separate the two pieces of the body. Does that make maintenance more difficult?
          Thanks
          Papa G.
            Thanks
            Papa G.
            all of my cages mount on the top of the body lip. bolts pass through both body halves and then through fender washers. you could also use some 1 inch flat strap instead of washers to spread the load more
