There is no where that I can think to put one. The seat needs to be supported by the frame, as simply adding something to the cargo area in the back will be too heavy for the tub.
You could take 5/8 all thread and weld some rod couplings to the frame and run all thread through the tub and put couplings on it and bolt on what ever you like.we use this stuff to hang many steel pipes and equipment from the ceilings in new buildings.
allthread works good for hanging pipes and stuff that dont move . but it does not like holding weight up that will be moving in all directions. if i was going to weld to the frame i would make some bracket and angel iron frame that goes under the top tub then u can mount a golf cart style rear seat on the back thats how i would do it
max2 with 3000lb winch,split shifter, off road lights, and 50 amp alternator
