Finally got my Max back from my now ex-FIL. He had it at our church for several years. Anyway, a couple of issues but the main one is a broken throttle cable. It has the stranded control cable. I have access to 1/16” aircraft control cable but I’m wondering why that and not a solid wire (i.e. choke cable) cable. Is there anything wrong with running a solid wire thru the housing instead of stranded control cable? Thanks!
MaxII throttle cable
Stens # 260-182, or Peerless #786201 $12.... Cut the ball end off and you're in business.
Same thing goes for that $35 choke cable.... R21CX10 $14
Fabricating brackets this morning to run motorcycle tensioners and the rollers are 19MM wide so they'll work fine for # 50 Chain. $7 each on Amazon...... "XtremeAmazing Heavy Duty Chain Roller Tensioner "
https://www.amazon.com/Stens-260-182...17047684&psc=1
https://www.easternmarine.com/buyers...-cable-r21cx10
https://www.amazon.com/XtremeAmazing...4338394&sr=8-5
