Recently tried to replace the gas cap on my Max II with a cap that has a built in gauge. I bought it from Route6x6 because it specifically said it would work on ALL Max II machines that have a "screw on" cap which is exactly what I have. That and I'll be honest I was too lazy to get up and measure the existing cap which would've enabled me to shop around a bit. So, the new cap arrived and when I tried it it bottomed out and wouldn't even start to thread on. Returned the cap to Route6x6 and they said that they tried it on 3 different Max IIs and it fit like it should. My question is this, did RI use the same size gas tanks in all their models? Was there a design or spec change at some point? Trying to figure out how my ( as far as I know) factory installed gas tank is smaller than what it should be. It appears to be factory with no obvious alterations to it or the bracket but I could be wrong. Were there aftermarket tanks sold that were very similar in design but not exactly the same dimensionally? Again, just trying to figure out this mystery. Thanks Cup
Max machines gas tank size
As far as I know there are only 2 gauge caps, one for the II and IV and one for the Buffalo, as they all use the same tanks. There were black and natural tanks in plastic.sigpic
Originally posted by ARGOJIM View PostAs far as I know there are only 2 gauge caps, one for the II and IV and one for the Buffalo, as they all use the same tanks. There were black and natural tanks in plastic.
The natural tank is 8-1/4 round with a 1-3/4 neck, tape inside measures 10 if your tank doesnt match then it has been changed. The buffalo uses an extension and is probably 2-3 deeper.sigpic
Originally posted by ARGOJIM View PostThe natural tank is 8-1/4 round with a 1-3/4 neck, tape inside measures 10 if your tank doesnt match then it has been changed. The buffalo uses an extension and is probably 2-3 deeper.Last edited by Cupwalker; 12-16-2021, 11:22 AM.
Forgot to mention that I measured the depth of the tank and it was 10", well 9 15/16" to be exact but I highly doubt a 1/16" is why the gas cap gauge didn't fit. Not sure what to think but I've already ordered a different gas cap gauge from another source so we'll see how it goes...thanks Cup
Originally posted by mfenmor View PostI've found those guage caps don't work after a year and cant see thru the lens after 2 years. I've never burned a whole tank in a day of hard riding so I just fill up in the morning before heading out.
