I have tried several chain lubes and some seem to just make a mess. Anyone have a go-to lube that I can try. Doing some maintenance and upgrades on my 1999 Max II, so you will see a few recent questions from me.
Any recommendations on chain lube?
Might not be the best thing to use...but I use the same sort of white lithium grease spray to get into the gears/chain at the back that's hard to reach...and I slather/gob on red grease by hand on the chains when I have it jacked up and can spin the wheels. Some flings off/squishes aside...but no big deal. If clumps accumulate on the idler sprockets I just knock it off with a screwdriver now and then. Before the winter I grease it up really well (probably too much). I had to park it outside last winter and the cover/tarps I setup split and it filled with water/ice (basically filled up to just over the axels with ice). When it was eventually warm enough in the spring where I could chip the ice enough out to free up the drive train...the chains/gears/sprockets/etc...were all in great shape. I just regreased it again. That's the longest it's been sitting "wet" (~4 months).
You could try Shell S2000 Red grease. It's says water resistant but I find it to be more waterproof. It stays put on my chain's and sprockets. Protects against Wear very well. Another I started using is Krazy grease. Used it on my dirt bikes and doesn't fly off. Washed them off and it's still there lubing the chain. I use it now on my bigfoot. Protects very well.
