Personally I have one day with a 23hp Vanguard, but that is going to change with my 21 Frontier 650 6x6 and I will report back this summer on it, the 23 was on a Max II and was good until 1 side carb clogged in the mountains of Tn.
As far as the 23 running hot in the Argos I believe this was an engineering failure that it appears they have been chasing since the change. This change happened 02-03 when the Vanguard engine mufflers were moved in the engine bay creating higher engine bay temperatures than the earlier y pipe to muffler out on the wheel well inside a box. We have encountered many heat issues with the 14,16 and 18hp engines in Argos many of which have been lack of fuel related and one reason you see many Frontiers and Bigfoots running with out hoods in warmer temperatures, it seems Argo has tried to abate this with hood scoops and engine bay temperature extraction fans ever since. The water cooled engines with real fans seem too have had far less extreme issues yet they are still apparent to some extent. IMO this was all created by moving the muffler inside and having a less defined muffler housing such as what was in the Twin and KB/Magnum machines allowing the heat to circulate inside. Granted there were cases of melted or distorted bodies being addressed.
I remember when the flat top Internal muffler Max II was being tested Jay was running a machine with either the 23 Vanguard or the 25 Command and had said he was working on heat issues, that may have been what brought on the introduction of their fresh air intake but I am uncertain. Likely I will be trying a 23 Vanguard in my II as I am turning 25s and once it's done I'll report back on it.
I would like to know how the 23 in the early Vanguard works as it should have the outboard muffler in it.
It should also have the older Twin style body which has more engine bay area.
