Ok so i bought a MAX II with a blown Rockwell 440. (The Rockwell 440 is for sale if anyone wants a parts engine {model 2F 440 7}. Pick up is preferred zip is 21015).
OUT WITH THE OLD AND IN WITH THE NEW.
I bought an B&S 18 HP Vanguard it was orginally on a water pump.
Model 350447
Type 1080 A1
Code 95011911
Now I need to mate all the pieces together.
1) So the clutch needs to swapped from the rockwell to the B&S
Will it fit? the shaft doesn't look tapered? The shaft doesn't have a key way. Do I need a wheel puller or will removing the bolt on the end of the shaft on the comet centrifigal clutch allow it to be taken it off?
Ideas?
Model 350447
Type 1080 A1
Code 95011911
Ideas?
