I have a 94 max with a 16hp Vanguard engine. I was wanting to add 4 of the off road lights and 2 power outlets. I was going to upgrade to the small optima battery or a similar high end battery. Will running this much be too much for the alternator on this small engine? Additionally, if I decide to also run a trolling motor, occasionally, will I need a separate battery for this, I would like to avoid the additional weight of another battery if possible? thanks.
electrical accessories, too much?
Here is one thread about it. I think there are a few other people who also did it. An alternator is an option from Argo.
Now days with the LED lights out there you can run TONS of light and use very little power. Here is a link to a nice trio of products from superbrightled.comOriginally posted by superclyde View PostI have a 94 max with a 16hp Vanguard engine. I was wanting to add 4 of the off road lights and 2 power outlets. I was going to upgrade to the small optima battery or a similar high end battery. Will running this much be too much for the alternator on this small engine? Additionally, if I decide to also run a trolling motor, occasionally, will I need a separate battery for this, I would like to avoid the additional weight of another battery if possible? thanks.
LED Truck Lights ? Super Bright LEDs
I know it is a bit after the fact but this might help others...
