I'm a new guy to the forum. I just finished restoring a 96 MAX II this winter (so to speak, I am still adding stuff as I have time). It was a real fun project to work on and I am happy with the machine so far.
To date I have:
Replaced all drive chains
Installed a new drive belt
Installed a new throttle and choke cable
Machined 2 solid axles (to replace bent axles)
Plated and re-welded frame where it had been bent / broken
Steamcleaned everything
Ground, sanded and painted frame
Installed carrier bearings for front two axles
Installed new wheel bearings
Installed new brakes (still not satisfied with the drums and need a park brake)
Patch hull where tires had rubbed holes due to axles running out of alignment
Fabricated and replaced gaskets at wheel bearings
Installed grease fittings on back 4 axle shafts
Installed new brass bushings on back 4 axles, machined new carrier rods for axles
Painted Body and Hull
Installed a blade style (6 gang) fuel panel
Rewired lights / replaced as necessary
Installed a bilge pump
Installed a recessed backup light in the center back of body
Build front rack and winch mount
I still would like to build a back rack that would allow (fairly easy) access to the engine bay so if anyone has any pics / advise I would appreciate it. I also want to install aluminum kick plates where I drag my feet climbing over the body but I haven't found a cheep source for the aluminum yet. Finally I would like to install a park brake, I am thinking about using a solenoid to block the chain (bar through chain link on each side) like on a skid loader but I don't know if it will release under load.
To date I have:
