How long will a max II with a 16 hp run on a full tank of gas? Thanx
Max II How Long
It depends on how you drive, how strenuous the terrain, tracks or tires, what size tires, weight, gearing, etc.
With that said, the last time that we went riding, I ran my Max II w/ 18hp from 10 am until 5pm without shutting it off except for lunch. I used about 3 - 3.5 gallons. Most of the time was slower speed riding with the occasional high speed run. Fuel isn't usually something you have to worry about for a one day ride.
I have a brochure somewhere that says your 16 hp motor's fuel consumption is .32 GPH @ 1/4 throttle @ 2,000 rpm.
An 18hp briggs gets .38 GPH.
I assume those numbers are with no load because that seems awful low to me. Don't get me wrong, these motors are very economical but I don't think they are that good.
Maybe that helps.
I have the 23hp Kohler, and even with the bigger engine, I don't think I've used much more than two full tanks in the 22 hours I've used it so far. Hard to say because I (unnecessarily) topped it off twice for recreational riding at an atv park. I left both days with lots and lots of gas left after hours of hard riding.Check out my new YouTube channel, TWANGnBANG.
http://www.youtube.com/user/TWANGnBANG
I have the Avenger with a 26 HP Kohler. Tank holds 8 gallons. Fill up in morning and you will be good for the day. I always have lots of fuel left in the evening. Like you car, jackrabbit starts, WOT and higher speeds will consume more fuel. You should be good for the day with a full tank. As you put more hours on your machine you will become more familiar with its fuel consumption.
Just to be sure, you don't actually unscrew the cap to see how much fuel you have. The stock max fuel tank is translucent. You should be able to see how much fuel is in you tank just by looking at the tank while sitting in you Max. There is no measuring involved- if it looks half full, it IS half full, etc.Originally posted by Kabruta View PostSo I measure how deep the tank is from the cap. Thats a good idea.. Thanks againCheck out my new YouTube channel, TWANGnBANG.
see a mower dealer/ repair shop for one.
