what are the things i should check for before i buy it? it has good tires runs good drives well all new tires but i want to know if there is anything i should check for that might be hidden all the chains are good no rust so what else should i look at? Thanks in advance
Buying A Max Iv Next Sunday Need Help?
Hello country
Get it up off the ground and check each axle for play is a good thing to look for. When its up check it out for hole,gouges or cracks on bottom of tub. Make sure it don't pull to either side and both side work similar when braking and accelerating. If it does it could be a minor air pressure issue or possible trans problems. Check fluid for milkyness to make sure water hasn't been in anything.
Good luck with it, hopefully turns out ok.
thankyou
Thank you very much for the info is there anything else i should look out forOriginally posted by LarryW View PostHello country
1996 MAX IV ,KUBOTA DIESEL
MAX II 30HP Bandolero
When i buy anything with a motor i like to run a compression check on the motor,very simple.Just a suggestion.Originally posted by countrycummins99 View Postwhat are the things i should check for before i buy it? it has good tires runs good drives well all new tires but i want to know if there is anything i should check for that might be hidden all the chains are good no rust so what else should i look at? Thanks in advance
