Stupid Chain !!!!!!!
  • Stupid Chain !!!!!!!
    ok on monday i broke a right rear chain on my 73 max II when i started looking at it more closely it seems i have #40 chain on the axles and up where the jackshafts are it has bigger chain on it bigger than #50 and the chain is loose on the sprokets is their supposta be bigger chain on the jackshaft. also the middle axle (same side the chain broke) seems loose now and i know it wasnt loose before the chain incident what gives im getting aggervated
    l___>
    000
    what good is it if it dont float
    Chain
    #60 should be what runs jackshaft to middle sprocket. If chain jammed hard after it broke it probably hurt the center axle bearing or???
      yo
      hey i called you yesterday to see if you got your chain situation sorted out so hows it going whats the news on your max we should plan a swamp run for next week since you couldnt make it this weekend
      1996 MAX IV ,KUBOTA DIESEL
      MAX II 30HP Bandolero
