Robinson, the secondary has a snapring that holds the 2 halves together. These are situated so that the individual halves of the driven clutch can open/close which allows the clutch to change its gearing, hence the name cvt. If the sheave halves are broken loose from their sleeve or hub then you will need a new clutch. If they are bent badly, you will probably need a new clutch, but most likely you will find that the inner workings such as the bore where it slides onto the tranny is wallowed out. Or the sleeves that are attached to the sheaves are worn and have enough slack to allow a wobble, or...
Before you give up on it, anchor it down so that it doesn't fall on your foot, take hold of it and see if you can find out what is causing it to wobble, it could be an easy fix, such as a loose bolt, or worn keyway/key.
I have a scanner and I ain't askeerd ta use it !!!
Thanks again.
Reckon he might want to slap in a red spring while he's at it? Ya know in case he "just has to" go to something like 25" tires later. Or mayhaps he's into speed...
R.I.P sage rogers 4 11 09 .
