max iv,solid axles?
  • max iv,solid axles?
    is there a quick way to tell if the axles are solid,thanks jeff
    1996 MAX IV
    Sometimes you can look in the frame at the end of the axles through the bearings.
    What is your serial number?
      and are they splined . like mike said get your serial # and call rec . robbie
        guy said dealer installed them and 26 inch tires,left recreatives on 22s and hollow axles,called today
        1996 MAX IV
          Then look at the end (inside the tub) of the axles. If they are hollow there will be a hole in them. It's that easy.
            thanks,going to look at it friday.
            1996 MAX IV
