If you are sick and tired of bearing problems and water leaks around your max consider these bearings. They are made to work in wet and dirty enviornments. Part number is Fafnir (now Timken) G1104KRRb. I paid $47.77 a piece for them from motion industries but you can probaly get a better price if you do a search for the part number.
Fafnir Bearings for the MaxIV
Looks like a good deal - especially never having to fart with replacing again. Now did I understand the vid correctly in that you don't have to lube these either? Zero maintenance would make the higher price more than worth it. Just to be freed of having to wrestle with replacement years down the road is worth it. I've done that on my Max II and it only gets worse as the vehicle ages.
If/when I replace the tires & wheels on my "new' Max IV it would seem to be a no-brainer to upgrade all the bearings to these beefier units while I'm at it.
Keep us posted on how they perform for you. And thanks for the infomercial vid clip! LOLLast edited by Dirty Harry; 09-23-2009, 06:09 PM.
Lub
Harry they don't ever need to be lubed. You can also seal around the flanges with rope caulk to keep the water out out of your tub.Originally posted by Dirty Harry View PostLooks like a good deal - especially never having to fart with replacing again. Now did I understand the vid correctly in that you don't have to lube these either? Zero maintenance would make the higher price more than worth it. Just to be freed of having to wrestle with replacement years down the road is worth it. I've done that on my Max II and it only gets worse as the vehicle ages.
heres a place for those brgs online at $33 ea
Bearing - G1104KRRB by: Tisco - Mowpart.com - Lawn mower parts are what we specialize in atHe who has not cruised the back country in a 6x6 , has not lived life to it's fullest
Cool
Thanks for the link!Originally posted by Robinhood02 View Postheres a place for those brgs online at $33 ea
it appears as though those brgs may not have the same quality of seals as those from Timkins ,but they are good quality and are greasable ( dont forget to line up the grease hole in brg with the grease nipple in the houseing)He who has not cruised the back country in a 6x6 , has not lived life to it's fullest
