Grinding Noise at top speed only?
  • Grinding Noise at top speed only?
    Im getting a grinding noise at high speeds only, seems like its coming from the engine clutch. Im not sure whats going on?
    Hello SmokeNchoke4x4,
    I have seen the driven pulley open up and hit stuff. It gets wider and need room. Does it do it in neutral revved too or only when your driving?
      Thanks, I checked it in neutral, and found out the trans clutch was rubbing the new motor table I installed. Easy fix
        Sweet!!!
