Quick question. How much, if any, play should there be in a Max II jack shaft when the chains are off? On mine you can slide the sprocket assembly back and forth on the shaft. It’s almost like it needs more washers/ spacers between the sprocket assembly and the frame. Should the sprockets slide back and forth on the shaft? Will this movement stop and self align when the chains are tight???? One more question, I’m pretty sure I already know the answer. Is there any built-in misalignment with the jack shafts and the T-20? I’m new to the Max and just want to know for sure that I’m fixing this thing the correct way.
Max II Jack Shaft ???
ive had the snap rings that hold the sprokets in place pop out of their groove and this alows the sprokets to slide on the shaft ,check to see if your max has snap rings holding them in placeHe who has not cruised the back country in a 6x6 , has not lived life to it's fullest
no snap rings on jackshaft . . but should be 2 cotter pins on one end it's betwin the washers and the mount inboard end the outside should be in the mount and through the shaft . robbieOriginally posted by duckhunt81 View PostQuick question. How much, if any, play should there be in a Max II jack shaft when the chains are off? On mine you can slide the sprocket assembly back and forth on the shaft. It’s almost like it needs more washers/ spacers between the sprocket assembly and the frame. Should the sprockets slide back and forth on the shaft? Will this movement stop and self align when the chains are tight???? One more question, I’m pretty sure I already know the answer. Is there any built-in misalignment with the jack shafts and the T-20? I’m new to the Max and just want to know for sure that I’m fixing this thing the correct way.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
R.I.P sage rogers 4 11 09 .
need some more washers . pm hey dan he works at max. he can tell you the right number to have at each end . mine has been apart so maney times it's probley not right . it needs to be alinding with the center sprocket abd the tranny . robbieOriginally posted by duckhunt81 View PostWith the cotter pins in, the jackshafts will still slide back and forward....I would say that there is about 1/2" or so play.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
i 2nd that motion . show me the way whipper . thanks robbieOriginally posted by whipper-ag View PostThe next Max II I build won't have a Jackshsft.
I hate the jackshaft
Whipper
next winter Beth's max is getting tore down to replace the lower tub. when it goes back together there will be a few less moving parts as wellOriginally posted by whipper-ag View PostThe next Max II I build won't have a Jackshsft.
Whipper
