so i think i missed something , did you decide to go with one drive motor on each side ,or six motors w/no chains ?? the reason i ask is because by putting the motors in series the first motor gets 100 %, the second gets 50 % of the first ,and the third gets 50 % of the second ,and that is assuming that the hoses cause no loss (flow restriction),meaning that the final motor in this series only gets 25% of the torque , this also assumes that the main tire never spins inside the track , if the lead tire spins you can quickly see how the overall power is lost real quick ,you would be FAR better off getting a 3 way flow control valve and run them parallel ,to equal the forces on ALL the wheels at all times , but the price of these valves are inhibitive ,given the choice of all the options available ,i would recomend one motor each side w/ a modified center shaft and upgrade the sprokets and chains to 60 from the 50s you have (with the single motor hyd. system you could even go to a chain oil bath type ,never change a chain again)
hydro max VI
aaah , that sounds good ,cant wait to see the project unfold, eh dont for get the pics , keep em comin ,triangle hi-drive sounds good
i've got an old "670 mach I" motor that ive been thinkin of useing to convert an old Max II into a ski-doo , maybe a top speed of 70mph , rear drive ,useing the front and center axles for the boogie and slider mounts ,then i gotta figger out how to control the thing ,skis? im not to keen on brakeing one side at those speeds LOL
good luck with your projectHe who has not cruised the back country in a 6x6 , has not lived life to it's fullest
........... which is pretty awsome
What road? I blaze my own trail!!!
