I purchased a '95 Max II 6 months ago with a 14 hp Briggs and Stratton Vangaurd. It tends to lose power and die while driving it(anywhere from 5 minutes to 1 hour). If I pull the choke out when it starts to die I can keep it idling but have no power to move. If I shut it off and leave it sit for an hour or so it starts up and runs fine, until it does it again. I cleaned out the fuel tank, replaced the fuel cap, fuel lines, fuel filter, and fuel pump. I have not touched the carb since I dont have a lot of experience working with them. Is there anything else it could be? I also noticed that the oil cap on the valve cover does not seal and leaks oil. Could the fuel pump lose vacuum pressure because of it? Any help would be greatly appreciated.
on the seafoam. it's great stuff. i run it in the fuel on all my small equipment. keeps the fuel dry and keeps from getting varnish in the carb.
adventures of the Great White North
