Hi All,
On my max IV the red toggle switch for the heated throttle cable wasn't working, (it had a loose connection and flickered on and off) so I went to radio shack and bought the identical one. I marked which wires went where (there are 3 contacts on the back of the red rocker switch for the heated throttle cable) and disconnected the wires. I had some other work to do on the max so it took me about 1 week to get back to hooking up the new switch. (BTW this "other work" involved removing the engine so I did some major work and hope I didn't mess up any electrical stuff. Once the engine was reinstalled, I snapped the throttle cable and had to jury rig it to work. I'm not sure if that has any effect on my issue.) When I hooked up the new switch it didn't work. I looked underneath to try to see if anything else was disconnected, and I did notice one black wire that was really short that didn't connect to anything. Now I'm really confused because I don't know how it was connected. Here's what I know:
A red wire from the back of the machine went directly to the middle wire on the heated throttle cable switch. A white wire from the back of the machine split (using one of those 3-way plastic crimp splicers), and from there one wire (now red) went to the first lead on the heated throttle cable switch and the other wire (white) appears to go to the hour meter. The 3rd lead from the heated throttle cable switch had a black wire connected to it. This wire was spliced (again with one of those 4 way plastic clamp splicers) and one went to the ignition, one went to the hour meter, and the other one is extremely short and went to nothing.
Does anyone know if this wiring is correct, or does anyone have information on the proper way to connect a heated throttle cable??? Unfortunately I don't have access to the old switch to even see if everything is ok.
Thanks.
Thanks.
