max II questions
I found some stuff from '85-'86 with that engine.
MaxII-4 model
You can get the tecumseh model number and that can ID the engine year. It wont necessarily be exact aatv year though as some manufactures get motors in bulk and may sit a while before use but it should be close.
The first letter designations in a model number indicate the
basic type of engine.
HH - Horizontal-Heavy Duty (Cast Iron)
VH - Vertical-Heavy Duty (Cast Iron)
OH - Overhead Valve-Heavy Duty (Cast Iron)
The number designations following the letter indicates
the horsepower of the engine.
The number following the model number is the
specification number. The last three numbers of the
specification number indicate a variation to the basic
engine specification.
The serial number indicates the production data.
Using model number OH160-170033, Serial 8044C
as an example, interpretation is as follows:
OH160-170033 - is the model and specification number.
160 - Indicates 16 horsepower.
170033 - is the specification number used for properly
identifying the parts of the engine.
8044C - is the serial number.
8 - first digit is the year of manufacture (1998)
044 - indicates calendar day of that year (044 day
or February 13, 1998).
C - represents the line, shift or plant in which the
engine was built at the factory.Last edited by LarryW; 01-10-2010, 11:43 AM.
yep everythings bolted in nicely but ill get some pics of the patch job on the tub and youll smile!! lol
well drove it today gas tank still sucks changed throttle but needs to be adjusted some chain slipping issues found a couple of worn sprockets and bad bushings also needs some chain anyone with a good line on parts for good prices let me know. at least i got to drive it though hopefully by summer it will be all fixed up.
