I have a perplexing problem with my Max II.Running tracks on quite hard snow,very crusty,though I have frozen trails that it doesn't break through.It makes a consistent crunching sound that I can feel in the sticks.It comes from the front left,though there are no chains on that wheel.I haven't yet pulled the floorboard and maybe drive it a bit with the floor out.The sound has a tempo to it I suspect making this crunching sound on every revolution.I don't think it is bearing as they checked fine before installing the tracks and it would only have about ten hours on it since then.Question: You folks out there who have suffered total bearing failure..what sound does it make?I realize the tracks change the load pressure on the bearing,I am running about 3 psi in the tires.
I keep it in a heated garage and it seems to be OK when first taking it out,maybe its ice, but it is consistent on the left side.
) to see if you can see anything. Also take some spray lubricant with you and when it starts making the noise spray the front left bearing and see if the noise gets better.
