Does anyone no where I can get the old style rear sprockets for the max iv. How much would they cost too? The factory doesn't carry them anymore.
Max old style rear sprockets
Richard's Relics sells 'em for $150 apiece, plus shipping. If you're a welder or know someone who is, you can build your own rear sprocket assemblies for a lot less and make a more rugged version, to boot. The standard sprocket tube has only a 3/16" wall thickness, so it's subject to elongation under load. There are probably other sources for this material, but I bought 34T and 26T sprockets from Shoupparts.com. These are the sort with a two-inch center hole and are designed to be welded onto a shaft. From Speedymetals.com I bought a length of steel tube with an outside diameter of 2" and an ID of 1.25". Fourth-grade math will tell you that provides a 3/8" wall thickness, which will be much less subject to wear and distortion. Another fellow on the site recommends adding a second bolt through the sprocket tube and axle, dividing the load even further.
I hope this helps you or maybe someone else reading this post. Good luck!
There! This looks like something that should last for a while. It's the do-it-yourself rear-sprocket assembly I mentioned before. 3/8" wall thickness and two 7/16" bolts through the axle.
It would have been finished months ago, but a heart attack back in April sorta' slowed things down.Attached Files
