MaxIV winch mount dimensions
  • MaxIV winch mount dimensions
    Hello all! I've just purchased a MaxIV and was interested in fabbing up my own winch mount. I was hoping some of you may know the dimensions of the factory mount (ie plate thickness, size, distance between plate where winch mounts and the rear plate, size of the in-tub plate). Any help would be greatly apprieciated. Thanks!
    Joe
    2000 MaxIV
    1969 F-250 Crew Cab 4x4
    2000 Jeep Cherokee
    "If some is good and more is better then too much is just enough."
    I second the motion.
      u can make it what ever size u wount . i made mine out of 1/4 4x6 angel . jest make shur ur backing plate is bigger than the outside plate and goes down in to the tubb so you are pulling on the whole mechine not jest the top . robbie
        Ok, well I suppose I can just fab something up. Thanks for the input! I just like the idea of making mine just like the factory option one.
        Joe
        2000 MaxIV
        2000 Jeep Cherokee
          darn, sorry bout that i was gonna get the dimensions for you ,i'll get them and post them asap
            here is a jpeg i drew up on the Max IV mount, hope i didn't miss anything ,it's all made from 1/8" steel
              Now that is service! Thanks for posting that.
                Awesome! Thank you very much!
                Joe
                2000 MaxIV
                2000 Jeep Cherokee
                  You are quickly approaching MVP status Charlie. Keep up the great work! Uncle Vin
                    i posted the Max II winch mount dimensions in my gallery if anyone needs it ,i did not include the fairlead mount in the drawing because most jobber winches come with it
                      I have been meaning to follow up with this thread for a while. First, to thank Robinhood02 again for posting the template, and second, to share my experience with using the template. I have been wanting to build a winch mount for my wife's Max IV for quite a while now so that she would have something to pull me out with. I finally got around to building one and decided to use this template. I knew that it was a template for the newer style winch mount found on the newer bodied Max IV's. The Max IV I was building the mount for was an older style body, so I wasn't sure that it would work. I decided to start with a paper template to check. I cut out the template, taped it, and held it on the front of the machine. It looked like it was going to be a good fit so I built it as drawn.
                      When I got the mount made, I held it up to the body, and when it was flush against the front of the body, the mount was angled down about 10 degrees too much. I ended up having to make the main mount at a 90 degree angle instead of having the back of the mount angled back 3/4" as shown. The only other change I had to make was with the external lower part of the mount. Instead of having the bottom angle at 45 degrees as drawn, I had to bend it to ~60 degrees.
                      Again, this is with an older style Max IV body. On top of that, the lip of this body was very mangled and pushed up, so I had to heat and attempt to straighten the body before I could even start measuring for the mount. This template definitely saved me lots of time measuring, and I ended up with something that is braced very well just like the factory mount. I am very pleased with the outcome, and again I have to thank Robinhood02 for taking the time to draw this up.
                      Hopefully my couple of notes will give anyone looking to use this template on an older style Max IV a few places to double check and measure before they begin. Here's a couple pictures of the finished product:
                        Winch
                        Very nice
                        Thank You
                        I will show this to my friends at machine shop and have them make one for me
                          IMG_0746.jpgIMG_0745.jpgI tried something different. No flex.
