Hi , I have a Max IV with the vanguard 16 HP engine and have a few questions about it,
1) the atv pulls to the right even on level ground, therefore you have to compensate for this by applying left stick, any ideas on the cause/solution to this problem??
2)to get the engine to idle you have to pull the choke lever out half way, i am assuming this is carb related, any suggestions about adjusting the carb??
3)when i go in water with it, its very slow/ uncontrollable in foward, yet very fast and controllable in reverse, can you reverse the tires, and if so , will you lose traction/ speed by doing this
4) my left chain that connects my back wheel to my middle wheel was popping off, but i adjusted the idler pully to tighten it up and it has worked fine since then, is this a fix for this, or do i have another greater problem??
sorry for all of the questions right off the bat, but you guys seem to really know your stuff, any help with any or all of these questions will be awesome, thanks so much
-Elliott
-Elliott
ERRR Dan I'm confused here
