My new Max II, and questions
  • My new Max II, and questions
    I sold my Argo Bigfoot 6x6, and now I´ve a Max II.
    I dont know what it is for a Bj. and Detaills for the engine: Engine is a JLO, I only know.
    I only have the serien number: 10013
    Can anybody tell me more about my new Vehicle ??
    Call Recreatives and give them your serial number and they'll be able to tell you all about it. Amphibious Six-Wheel Drive All-Terrain Vehicles: MaxATVs - Call 1-800-255-2511 They're very helpful folks, and they'll be able to hook you up with just about any part that you might need.
      Thanks for it.
      But I´m in Germany, I dont call to USA.
        Looks like you have the 21" tires that are the best swimming tire for a MAXII
          Originally posted by BigBlogger View Post
          Thanks for it.
          You could email them.
            Really ?? On the Argo I had 25x12,5 - 9 Rawhide II.
            On the Max the 21" tires looks soooo small. But they are new, thats good.
              Thats a good Idea.
              I will oil the chains in the rear.
              By the Argo I coud very easy take the ground plates away, to get to the chains. And by the Max ?? How ??
              Same to work to the engine. The Argo had a hood you can open. And by the Max ?? There is no hood. (the picture with the engine is still from the seller)
              Have anybody an repair description for the Max as "PDF" or something, you can mail me ??
                You just loosen up the nuts and bolts that hold the top and bottom of the body together and the top half of the body will lift right up. To get to the front chains just remove the floorboard/seat.....you will have to work it back and forth a little bit and it would help to have a second person lifting it out with you.
                  Ok.
                  and the roll bar ??
                    The roll bar is attached to the upper body. Just remove the wingnuts like jpswift1 said and raise up the body.
                      Ok.
                      By the Argo it was easy to came to the engine and chains.
                        Now the Max engine runs. Thanks for help.
                        The clutch by the engine from the drive belt, is very loud by low engine speed. It seems like rattle.
                        What coud seem the reason for it ??
