I just want to pick you fellers brains for a minute on a small problem I've noticed with my Max. I've only had time to test ride it in the field across the way since I bought it, but I've noticed that if I make a sharp left turn under full throttle it does fine, but if I make a sharp right it bogs down and almost dies, but then recovers. Have any of you ever experianced this? I also noticed that the clear fuel filter is never full; it gets just enough gas in it to touch the element inside.
BTW, I cleaned the carb and installed a new fuel pump when I bought it, but it did sit a lot over the years.
Thanks!
Thanks!
Yeah and it's probably factory set to run as lean as possible to keep emissions down. That's probably the whole problem...
