Is there a secret to removing the set screw that seems to hold the main gear onto the rear axle, or should i just accept the fact I will lose all my knuckles before this adventure is finished?
I'm mucking out a 2003 Max IV i just bought. The Max was hardly used but the previous owner obviously wasn't big on cleaning and maintaining it either. I lifted out the engine and tranny, and wanted to grease the inside rear bearings. With a 90' coupler I was able to get grease into one zert. But no luck with the other side bearing. I thought if I moved the gear, i could try a straight coupler, clean the zert and or change it or the flange. That's when i met the set screw from hell.
The axle is splined; the gear held to it with a set screw like you would find on a bearing collar (very different from the bolt holding gear to axle on my '93 Max.
QUESTION: can i move the gear to get at the zert? Is the zert pressed into the flange or is it screwed? Does anyone know where to get zert extensions? There is NO WAY to make these bearings part of the regular weekly maintenance without some serious modifications. A midget gymnast couldn't service those bearings, never mind me, the Friendly Giant.
