Is there an easy way to tell if the axles on a Max II are hollow or solid, while they are still mounted on the Max?
Solid axle identification
I would probably just loosen the components holding your front axle (since it is easy to get at) and then just take a look inside your axle, maybe stick a screw driver in it, and see if it is solid all the way through or not. Other than that, I dont think there is any way to tell."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
