MaxII bearing replacement
  • MaxII bearing replacement
    Got my new bearings on the way. Going to replace all 6, was wondering if there is a secret to doing this. What are the steps if any. I know you guys have a lot of shorts cuts that make things a lot easier. This is my first 6x6x and yeas I am learning as I go. Thanks
    Mike did an article on this very subject. http://www.6x6world.com/forums/conte...placement.html
    i just typed "max bearing replacement" into the search window and it was the 4th one down
      I just read the how to... thank you Mike! Very well done! I just hope I never have to do it
        thanks for the info, it will be very helpful .
          I am going to change the bearings on my Max II,think the bearings are still functioning ok but the seals are gone and with this will bring dirt in the bearings.Mine has bearing cages.The article on bearing replacement found here is excellent but on a machine without the cages.To change with the cages is there any extra consideration or is it "more of the same".?Any ideas or first hand experience will be greatly appreciated.
