ok I JUST GOT A MAX TRYING TO GREASE ALL THE ZERKS THE ONES ON THE INSIDE SPROCKETS I CANT GET A GUN TO GO ON THEM HVE TRIED 3 DIFFRENT FLEX HOSE GUNS NOW ANY ADVICE?ALSO HOW MANY ZERKS ARE ON A MAX 4 AND WHERE IS THE LOCATIONS,DIRECTIONS ARE KIND OF VAGUE,ANY SERVICE MANUALS OUT THER FOR THESE THINGS?
Need help grease fittings
I was needing to lube my zerks for the first time last week and ran into the same problem. I remembered a handy little adapter that we used to have at an Express Lube I used to work at, but I couldn't find one anywhere. Finally I got on tooltopia.com and found it. Here's a link: ToolTopia.com - Search It slides onto the zerk from the side (90 degree angle) and is an awesome little tool. It just plugs onto the end of your grease gun, no tools required. I used mine and had all the fittings greased in a matter of minutes. It makes it easy to get to the outer wheel bearing zerks too without having to remove the tires. I highly recommend it!
BTW every axle bearing has a fitting. If I remember right it works out to 12 fittings (two per axle, one inside the tub and one outside, x 6 axles).Last edited by fomocoguy; 08-30-2010, 08:32 PM.Joe
2000 MaxIV
1969 F-250 Crew Cab 4x4
2000 Jeep Cherokee
"If some is good and more is better then too much is just enough."
